nj111
- Jan 10, 2008
- Forest of Dean UK
This might help a few people, if you are maybe slightly older like myself and a bit set in your ways! You may also have a great CAD/CAD system that does all you need it to do for your slightly older machines, like mine - but it can't be installed on a modern Win10 system. In my case XP was a new as I could go. The cost of upgrading CAD/CAM to run on Win10 in my case would be many thousands.
The problems of safe browsing, checking emails etc with XP these days just get worse all the time, mine was just getting slower and freezing with this sort of application.
But a fresh installation of XP used only for CAD/CAM runs quickly and does the job just fine without being forced into a massive investment in new software and the downtime learning to use it.
I finally gave in and bought a Win10 pc for internet / emails /word-processing etc, therefore ended up with two pc's on one desk. This then leads to the problem of emails coming in with dxf drawings etc which needed to be transferred to the older PC.
I couldn't establish a network between XP and Win10 but heard file sharing could be done with a special USB cable so bought one, for about £20 it's described as:
Ugreen USB 2.0 Easy Transfer Data Link Cable ,Compatible with Win10/Win8/Win7/XP
This works great to drag files from one PC to the other, but what it also does is something even more useful.
If you move the mouse pointer off the edge of the screen of either PC towards the other PC then the mouse and keyboard takes control of the other PC. So one keyboard and mouse works both pc's - whichever way round you want. This saves a massive amount of time and means I can carry on indefinitely with the CAD/CAM software I prefer, I just have two monitors to look at. I bought mine here. ebay item 192028078366
Ugreen USB 2. Easy Transfer Data Link Cable ,Compatible with Win1/Win8/Win7/XP | eBay
