Is there anything to watch out for when starting a program -not- at the beginning? using G90 absolute programming..
The actual program ran fine from start to finish but threw up a burr on the chamfer pass... I then started mid-program from the contour pass (N5640) to clean up the burr and the spindle went, or at least tried, to Z-7.ish destroying all you can imagine.
If anyone wants to see the code....
It's not a one off error, I ran both ways again with the same results, start from beginning and it's fine.. from N5640 and it tries to crash.
Maybe it's just the machine, it's new but was recently updated to fix other known bugs.
I just want to know if I'm to blame before I go pointing fingers.
