I am trying to post out a 4th axis program an a Fanuc 31i. I am using Surfcam for the program. When I post out the program it doesn't put a feed rate on every line with G93, causing an error on the control. Is there a way to edit the post processor to make it put a feed rate on every line. I know the inverse feed rate isn't modal, requiring a feed on every line with G93. A previous employ set up the post processor. Not Surfcam, so I can't get any help from them since they didn't set it up. I have worked around this in the past by adding the feed rate in the post manually. Any help would be greatly appreciated.
Thanks for looking,
Thomas
Thanks for looking,
Thomas
