Surfcam post processor not putting feedrate on every G93 line
Thomas68
Jun 19, 2021
I am trying to post out a 4th axis program an a Fanuc 31i. I am using Surfcam for the program. When I post out the program it doesn't put a feed rate on every line with G93, causing an error on the control. Is there a way to edit the post processor to make it put a feed rate on every line. I know the inverse feed rate isn't modal, requiring a feed on every line with G93. A previous employ set up the post processor. Not Surfcam, so I can't get any help from them since they didn't set it up. I have worked around this in the past by adding the feed rate in the post manually. Any help would be greatly appreciated.
Thanks for looking,
Thomas
You can edit posts in Surfcam, open the post and see if it gives you the option to add the feedrate on every G93 line.
