caluche123
- Jan 29, 2021
I am working with a Fanuc Robodrill equipped with a rotary table (4 and 5 axis) and I have to mill a part taking into account that this milling must be performed along the perpendicular direction of the flat upper surface of the part. In order to do it, The machine is equipped with Renishaw inspecton probe with the objective of capturing the real angle around the X and Y axes. After getting those angles we would like to compensate them with the objective of getting said perpendicularity during the machining. I am using the G68.2 but i am not getting good results.
I am using the following code "G68.2X0Y0Z0I#953J#954K-90" where #953 is the angle read by the probe around the X axis and #954 is the angle read by the probe around the Y axis.
Is there anything wrong? Should I compensate those angles by using another code?
I would really appreciate if someone could give me an idea of what I am doing wrong.
Thank you very much.
