01-17-2021, 10:32 AM #21
Design something in inches, if you wouldn't mind - like wechat, I don't do metric cuz I don't have to, and it sucks
- and I'd never use a "4 mm grooving tool" for something like that.
Meanwhile, are you sure bobcad or fusion can do this ? I mean, all the low-end modern cam systems are superior, yes ?
https://youtu.be/FGK8fx9CKHM
p.s. I'd never use a cam program to create a simple thread, either. It's a waste of time and a complexity you don't need.
01-17-2021, 10:36 AM #22
lol, that's a bit far fetched.
Modern CAM systems are more than just toolpath creators. Cutting simulation, machine optimization, automation, integrated CAD, etc, etc, etc. APT is just not comparable to todays CAM. Can it do some of the same things, sure, but at what cost to efficiency? 'just cause you can doesn't mean you should'
If you wanted to go down this odd ball thread programming path with APT, you'd probably be better off using CAM anyways, even if the CAM system doesn't have a toolpath for it. For this thread scenario, you could program a groove that is the shape of your desired thread with whatever tool you wanted, and use those groove points as starting points for a G32 thread cycle. You would have to manually edit the gcode to do this but it would work. Not fully automated like a built in toolpath would be but at least you're getting your CAM system to do the heavy math for you.
Comparing APT to CAM is like comparing DOS to Windows!
01-17-2021, 10:38 AM #23
01-17-2021, 10:39 AM #24
Okay, that I can accept. There's a lot of other stuff that flies under the heading "cam" now, and APT is just for creating toolpaths.
But I don't accept that there's anything toolpath related that "modern" systems can do that APT cannot. In fact, for real control, there's a select group of people still running NCL and its brethren because graphics toolpath generation doesn't do what they need. That's why NCCS still exists.
Originally Posted by gregormarwick
And I would never use a stupid grooving tool for cutting threads. That's dumb.
So figure out a different model.
01-17-2021, 10:45 AM #25
01-17-2021, 10:48 AM #26
No, what's effective is putting the part in a thread grinder. Then you get a nice part
I would only consider doing a worm that way if I was desperate. What the heck are you making ?
(This is pretty pictures on top of an APT sibling. In fact, it's probaly APT itself behind the covers, but APT is public domain so companies do not like to admit to selling that. All the low end cam systems can match these capabilities ?)
http://cfnewsads.thomasnet.com/pnn-pdf/511762.pdf
01-18-2021, 12:20 PM #27
01-20-2021, 03:18 AM #28
01-20-2021, 12:28 PM #29
Custom Thread—Lathe Toolpath in Mastercam 2021 - YouTube
This is what I think the Op is referring to, which to my knowledge NX cannot do.
01-20-2021, 01:03 PM #30
