Dan B
Hot Rolled
- Feb 18, 2006
- Ontario, Canada
First, are these two products essentially the same? I have demos for both, and I find that RhinoCam seems to be missing some toolpath editing features. For example, in VM I can window around toolpath and trim it away, just like WorkNC. In RhinoCam I see the buttons to delete path, but none to select toolpath. Are they hidden somewhere?
On the subject of trimming toolpaths, is there no provision to recalculate retracts after trimming? I found if I trimmed away a small area, there was some serious gouging where the new connecting paths really should have been retracts. How do you do this?
Also, I can't seem to find anything about holder collision checking. Does VM/RhinoCam have this feature? If so, they need to add the ability to better define holders. The rectangular holder that is part of the tool selection does not come even close to something like a heat shrink holder, that is narrow and tapered. I suppose if the holder is irrelevant, then it doesn't really matter. Not doing any type of holder collision check would be my main reason for not considering VM/RhinoCAm as a serious professional-grade CAM aplication.
Dan
Dan
