PartScrapper9000
- Nov 14, 2018
I have been having this issue for a while and have just been dealing with it, but I figure its probably time to ask for help. Excuse my formatting, this is my first post.
As I said in the title, at the start of all tool paths, the machine goes up to z15 and crashes into the limit switches. Every time I have to jog the machine back down then run the next line.
The line that appears to be causing this is "G43 Z15. H1"
I can't figure out why the CAM software (Fusion 360) would try to do this as I have not seen this occur on other machines. Although other machines I have seen were not using Fusion 360.
I am running mach 3 by the way.
Is this to do with the clearance and retract heights and is this normal? Additionally, will deleting the line have a negative effect on the tool path?
Thanks in Advance!
Thanks in Advance!
