FinelineMolds
- Jan 15, 2019
This position is responsible for supporting the mold making and repair operations. Must have a advanced knowledge of what a mold is and how it functions. This individual will collaborate with fellow machinists and organize internal resources to complete mold maintenance work in a timely and cost effective manner. Must meet quoted deadlines while documenting work being completed; must have a proven strong mechanical and technical background and the ability to troubleshoot and problem solve.
Must have the ability to run machine tools in the shop, (mills, lathes, grinders, torches, heat treat, saws, and CNC equipment, Wire EDM equipment).
Responsibilities
• Operate Wire EDM and CNC Milling Machines
• EDM and CNC experience required
-Specifically on the following Machines: HAAS TM1, Sodick AQ327L & MC650L, Bostomatic 12G
Fadal CNC 88 HS
• Disassemble molds and determine parts needing to be repaired or replaced.
• Clean mold plates and all components.
• Check for proper gating, venting and cooling of mold.
• Record and maintain all maintenance documentation as required.
• Polish cavities and cores to specified finishes.
• Must be able to troubleshoot and analyze problems with molds.
• Read and understand blueprints, sketches, and schematics relating to molds.
• Have the ability to use all measuring tools (micrometers, calipers, indicators, travel dials, and their applications) to measure and determine proper mold and component fits and tolerances within .0002” to .0005”.
• Construct, rebuild, and repair mold components per prints, using any or all machine tools available in Mold Repair area as well as the Tool Room.
• Assemble mold and components maintaining proper dimensional tolerances.
Required
Minimum Education and Experience:
• High School Diploma
• Minimum 10 years of experience operating CNC & Wire EDM Machines
• Molding Knowledge Assessment will be administered
Minimum Knowledge, Skills, or Abilities
• Demonstrate mechanical aptitude necessary to troubleshoot and repair equipment
• Machine modifications and process improvements on equipment in a manufacturing environment
• Read mold drawings
• Use of micrometers, indicators, height gauges, etc.
• Ability to operate machine tools
• Molding, mold design, material flow and mold steels and their applications
• Troubleshooting skills to be used for continuous process improvement
• All qualified candidates will be required to complete a Mold Maker Skill Assessment**
• Moderate lifting up to 35 lbs.
Please message me or email me at [email protected] to submit your resume.
Responsibilities
Fadal CNC 88 HS
Required
