CNC Programmer - BRYAN TX 25-29/hr
Likes Likes:  0
Results 1 to 3 of 3
    Nov 2009
    1,116
    73
    311
    Default CNC Programmer - BRYAN TX 25-29/hr
    25-29/hr depending on demonstrated skills
    NOTE! There are assessments that must be completed within 7 days of applying. We will send you the assessments after you have applied. You will also be expected to send us a 1-2 minute video about yourself, no exceptions to either of these. BE PREPARED TO DEMONSTRATE YOUR ABILITIES
    The job will be posted on indeed shortly you will need to apply there, but please email me so i am aware you are interested from here.
    [email protected]
    CNC Programmer/Machinist - Bryan, TX - Indeed.com
    Need to be ready to fill a position on either of the below schedules.
    2nd shift 1:30 PM - 10 PM Sunday - Friday
    Or 1st shift 6:00 AM - 2:00 PM Sunday – Friday
    WATCH THIS VIDEO ABOUT WHERE YOU MAY WORK!
    YouTube
    Responsibilities / EXPECTATIONS include:
    Programming (Okuma OSP + HAAS), set up, and operation of multi-axis CNC machine tools include VMC (Okuma M560V) and Mill Turn centers (Haas & Okuma).
    Perform offline programming and CAD using Fusion 360. Applicant must have 1+ years of CAM Programming experience and an excellent knowledge of G-Code.
    Set up multiple machines with minimum time and utilize optimal feeds, speeds and cutter combinations and tool selection.
    Use and maintain precision inspection equipment such as micrometers, indicators, electronic height gauges, optical comparators, and gauge blocks.
    Read and understand engineering drawings and blueprints, including GD&T, conventional dimensioning/tolerance, as well as the ability to infer tolerances for a given part function.
    Interface with engineers directly to accomplish design goals and manufacturability of parts.
    Apply thorough knowledge of machining materials such as aluminum, stainless steel, plastics, alloy steels, and various tool steel.
    Manufacture parts with close tolerances +/- .0005″ and achieve surface finishes 16RA or better with a minimal scrap rate. Will be expected to clean/debur and assemble parts while maintaining quality.
    Be capable of making parts from start to finish using blueprints and/or CAD files with little or no supervision.
    Must have good communications skills and be willing and able to act as a company representative.
    the ideal candidate will also have the following traits:
    A passion for machining and creating
    Attention to detail
    Willing and eager to learn anything to improve themselves and their teammates
    Reliable and trustworthy
    *Be a part of the Odin Heavy Industries team, an industry leader in the
    design and manufacturing of engineered polymer solutions. Utilizing the most
    advanced material compounds, manufacturing processes, and engineering
    expertise, OHI develops custom shapes, sealing systems, and components to
    satisfy even the most complex applications. Focusing on several service
    markets, such as Space Industry, Oil & Gas, Nuclear, Chemical Processing,
    Power Generation, and Semiconductor, our customers rely on OHI’s material,
    design, and manufacturing support for their critical polymer applications.*
    May 2011
    New Jersey
    2,298
    204
    1257
    Interesting, plastics can be a real challenge, moreso than metals. Worked in that industry for a little over a year...learned a lot about machining lol. Good opportunity to really expand your knowledge.
    Nov 2009
    1,116
    73
    311
    Most of the first 6-12 months in this position will be mill turn metal machining and simple 3 axis vmc metal. Plastics will come later.
    There are very few shops in the world that can do what we do in composites. You would learn some skills not many people know or practice.
