Hiring Machinists - Sulzer RES LaPorte TX
Results 1 to 8 of 8
    Feb 2013
    Houston TX
    3,904
    16
    1994
    Default Hiring Machinists - Sulzer RES LaPorte TX
    I am a supervisor in the Core Machine Shop of the Sulzer RES facility in LaPorte, we are looking for machinists. Both manual and CNC as well as for days and nights.
    We are a rotating equipment repair shop, we work on nearly all facets of rotating equipment repair. Our common work scope is related to compressor and turbine rotors as well as related case and internal work.
    We are a predominately manual shop, with two Mazak CNC lathes, as well as a 6" Union floor mill. Familiarity with Mazatrol and Heidenhein controls would be a plus.
    Our manual machines range in size from 16" engine lathes and bridgeports to 100" swing lathes and a 6" floor mill.
    Here is a video tour of our facility, a portion of our shop is shown from 4:00 to 4:30
    Take a tour through Sulzer Turbo Services Houston Service Center - YouTube
    Below is a list of common tasks in our shop, familiarity with these is preferred;
    • Line boring - both in a machine and with portable machine tools
    • Split part work - such as inserts, diaphragms and IGVs
    • HBM operation - Aligning cases to machine split lines, machine keyways in rotor shafts, drill steam balance holes
    • Horizontal lathes - Machine shafts for grind, align shafts and rotors in a lathe, chase threads to fit, reclaim centers
    • Vertical lathes - Align split parts such as diaphragms and IGVs to machine crush pins or inserts
    • Cranes and rigging - Safely lift rotors, cases and flip parts as needed
    • CNC lathes - Machine new shafts and discs from forgings, machine labby seal sleeves and misc trim parts
    • CNC mills - Set up and align cases to machine split lines, machine axial entry blade roots
    • Turbine rotor work - Install and machine seal strips, machine rotors for weld repair, machine shaft stubs, final machine weld repaired rotors, machine turbine blade roots, install tie wire, machine coupling fits, etc
    For more info please contact me at;
    [email protected]
    (281)515-1352
    or
    Drew Grindley
    [email protected]
    (281)739-3467
    or
    Raul Sanchez
    [email protected]
    (346)233-6017
  2. Likes tim9lives liked this post
  3. #2
    Jul 2004
    Houston, TX USA
    31,832
    I think its wonderful. In less than 7 years Matt has gone from very interested and very smart youngster to boss!
  4. Likes lazz, tim9lives liked this post
  5. #3
    Mar 2006
    PHILIPPINES
    3,023
    1097
    1456
    Definitely a nice shop. Much cleaner than Continental I must say. Nice work with the drone in the vid as well, too bad a disgruntled employee had to chime in on the comments. Oh well, cant please everyone.
  6. #4
    May 2005
    Republic of Arizonia
    1,764
    546
    Nice shop.
  7. #5
    Feb 2013
    Houston TX
    3,904
    16
    1994
    Quote Originally Posted by johnoder View Post
    I have been very fortunate, thanks in no small part to folks like you John.
  8. Likes tim9lives liked this post
  9. #6
    Feb 2013
    Houston TX
    3,904
    16
    1994
    I’ll add some pictures of some of the jobs we’ve done to bump this thread up as well.
    For a young guy that wants to learn, there isn’t much better of a place than my shop. The volume and variety of work that we see is amazing. Attachment 305338
  10. Likes eKretz, tim9lives liked this post
  11. #7
    Mar 2006
    PHILIPPINES
    3,023
    1097
    1456
    Seeing that Climax sure brings back memories. I always enjoyed portable machining due to the travel (and money). Nothing like being up on the plains in a few feet of snow inside a 60" valve recutting a seat. Put some plastic over each end with a Kerosun heater and some vent holes and 3 hours per pass,,, easy money.
  12. #8
    Oct 2014
    Maine
    1,300
    257
    626
    The Unions are nice machines. What are the travels on yours?
