motion guru
- Dec 8, 2003
- Yacolt, WA
Applied Motion Systems, Inc. is a world leading manufacturer of Factory Automation Equipment and Control Systems for a broad range of industries. We have a well established team of skilled Systems Engineers with expertise in Automation Systems, Motion Control, and Coordinated Drive System design and programming. These systems use state of the art industrial PLCs, HMIs and Vision systems with integrated safety.
We are looking for talented engineers to join our Systems Engineering Team with a particular emphasis on CNC Machine Tools. AMS deploys Sinumerik CNC controls in complex multi-axis grinding, carbon fiber tape laying and general machine tool applications. If you are passionate about learning and have a natural inclination toward mechatronics and programming using well organized code . . . and you are looking for an environment where you can work alongside skilled engineers while learning industry best practices – we invite you submit your résumé and cover letter for consideration.
Responsibilities include:
AMS is a Certified Solution Partner for Siemens using Simatic PLCs and HMIs in addition to Simotion Motion Controllers and Sinumerik CNCs. AMS is also an Automation System Integrator of Rockwell products with expertise with Logix PLCs, CIP Motion and Kinetix / PowerFlex 755 Drives with Integrated Safety.
We are recruiting for several positions at present and while experienced candidates are encouraged to apply, we will also consider recent graduates with an engineering degree and demonstrated competence in programming / control system design related to course work and/or personal projects.
This position will provide you with the opportunity to gain experience and develop competence with Siemens automation products, in addition to the full suite of Rockwell hardware platforms, Cognex Vision Systems and Industrial Robotics. Previous experience with Rockwell and/or Siemens development environments is beneficial.
e-mail resume to [email protected]
AMS Systems Engineers design Factory Automation and Coordinated Drive Systems including hardware integration and programming using off the shelf industrial automation hardware and drives. You will work with Electrical Engineers to develop multi-sheet schematic packages using AutoCAD and AutoCAD Electrical. You will collaborate with Mechanical and Manufacturing Engineers and develop software to optimize machine HMI and machine homing / workpiece probing processes and machine process state sequencing to provide intuitive machine controls.
