1.4375 acme thread possible?
Results 1 to 14 of 14
    Jan 2020
    142
    92
    41
    Default 1.4375 acme thread possible?
    I am in the process of making a new lead screw for an old lathe. It is definitely Acme 4tpi and the diameter across threads is 1.429 and the root dia is 1.156”. It seems I cannot find any specs within these measurements for an acme thread. Seems like it’s maybe supposed the be 1-7/16 acme but all literature I have goes from 1-3/8 acme to 1-1/2 acme. Any thoughts?
    Jan 2005
    Victoria, Texas, USA
    4,971
    3759
    1455
    If that is on that old Lehmann lathe, it is 1.4375-4 Acme thread. Used to have a copy of the original drawing on that leadscrew. Lost many years a go. The material they used to use was 1144 TPG or Stressproof. Used to be a place in Dallas that made the leadscrews for Lehmann after they moved from Saint Louis, Mo. Unfortunately, they are no more. They milled the thread on those leadscrews.
    Edit: Send me your email and I'll send you a print out of the thread dimensions for that thread. Ken
  3. Likes TexasAggie, Paolo_MD liked this post
    Jul 2004
    Houston, TX USA
    32,574
    On a shop built thread mill
    Machine Tool and Repair
    Best wire size for 4 pitch will be .12911 - these will be flush with OD (per Van Keuren catalog 31)
  5. Likes TexasAggie liked this post
  6. #4
    Jan 2020
    142
    92
    41
    [ATTACH=CONFIG]330525da1a2aeb-df97-44b8-87b1-892a6fe69b63.jpg330527 I’ll be dammned. Sure is. I’ve been in the feed double bevel as it rolled the key finally and leadscrew is jumped on a good portion. Thought I’d fix it all while apart.1520c665-a6ca-49c3-ac20-f92068b5db0e.jpg bronze miter gear is pretty smoked but it is a weird one. 60 tooth with 5” PD
    Attached Thumbnails Attached Thumbnails 53d58abc-dc67-4052-b03d-18cb08c49a85.jpg
  7. #5
    Jan 2020
    142
    92
    41
  8. #6
    Jan 2020
    142
    92
    41
    Thank ya sir
  9. #7
    Jan 2005
    4,971
    3759
    1455
    Email sent.
    Used to have a bunch of those bronze bevel gears with all sorts of wear on hand. Don't remember what happen to them.
    EDIT: TexasAggie, John doesn't know it, he has the bevel gear cutters that was used at one time for cutting the teeth on that bronze gear. That's if John still has all of them gear cutters my family donated to his shop many years ago.
    Ken
  10. Likes TexasAggie liked this post
  11. #8
    Jan 2005
    4,971
    3759
    1455
    Quote Originally Posted by johnoder View Post
    John,
    That thread mill Machine Tool & Repair had was made by a company called "SHIELDS". I don't know if you remember, we had one just like it, way back in time that sat in the yard by the old planer you bought from us.
  12. Likes TexasAggie liked this post
  13. #9
    Jan 2020
    142
    92
    41
    That bronze gear is factory huh. Mine almost shot tempted to try and make a new one or remake entire bevel with off the shelf parts with same ratio.
    Got feed shaft keyway welded up about to mill it on k&t 4H 87c4f283-d87b-4256-b200-c476c79ec839.jpg7fae4ec3-b92a-4a79-91dc-eb42d0ebf2f6.jpgd79daf54-bd9a-42da-bdce-143200c316c4.jpg5b176d91-5e54-4672-93db-ef153612c455.jpg2f0fa068-bb2f-4341-a9ae-90f407ba4642.jpg
  14. Likes 4GSR liked this post
  15. #10
    Jan 2020
    142
    92
    41
  16. #11
    Jan 2005
    4,971
    3759
    1455
    Quote Originally Posted by TexasAggie View Post
    Oh, that's nothing, you should have seen the one I replaced. The teeth were wire thin and the bearing area was built up and turned to a new OD as well as the apron wall was rebored to a new dimension! It was a mess redoing! Yours looks sooo clean compared to the one I rebuilt.
  17. Likes TexasAggie liked this post
  18. #12
    Jul 2004
    Houston, TX USA
    32,574
    Have Ken's old folder on his 18" X 11 foot lathe - serial 1243 - it has two lead screw drawings at least - 1202 - C and one unreadable
    Both have a 3/4 thread on the end, one 10 pitch and one 16 pitch
    The wire size on 1202-C is given as .125 and the dwg specifies ONE wire with a measurement of 1.447 / 1.445 over that one wire
    Material was given as 1040 ground stock 1 7/16 O.D.
    Length was 9 foot 5 1/4" for that 11 foot bed
    Some pictures
  19. Likes 4GSR, TexasAggie liked this post
  20. #13
    Jan 2020
    142
    92
    41
    Thank you for this info John. Exactly what I was looking for! First time I’ve ever seen a 1.4375 acme thread spec
  21. #14
    Jul 2004
    Houston, TX USA
    32,574
    You are sure welcome Joe. Also emailed the two just now - probably be more sizeable
  22. Likes TexasAggie liked this post
