1938 Cincinnati 2MH - handles don't move the table anymore - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21
    Jan 2016
    Indiana
    117
    76
    42
    No update yet, I had to handle a few other projects first. I did get the cross feed nut back into place with a new set screw. Gonna tackle getting the table off again at some point in the next few weeks. Too much work, not enough time!
  2. Likes texasgunsmith liked this post
  3. #22
    Jan 2016
    Indiana
    117
    76
    42
    I had some time tonight so I played with it some more. After getting the cross feed nut back in place and loctiting a new set screw in, I decided to see if I could get the table moving to the right this time. It was stuck pretty good from all my attempts to push it off the left side. This setup worked nicely, using the forklift for an anchor and bolting the machine to the concrete with some big tapcons.
    Turns out, it was indeed a bent gib screw.
    I'm gonna order some 4140 and machine a new one, but otherwise I'm back in business. Table moves freely with the gib not all jammed up, I can even push it around by hand instead of ramming it with an 8500lb forklift
    Being able to actually adjust the gib AND have my X-axis back will go a long way towards the performance of the machine, I suspect.
  4. Likes texasgunsmith, svs, 4GSR liked this post
  5. #23
    Feb 2016
    1,992
    1384
    797
    Quote Originally Posted by Dope View Post
    That's awesome, glad it worked out. I'm still in the process of putting mine back together, decided to go a little further getting things cleaned up, getting lube system cleaned and working, etc.
    Also looking forward to running mine with gib adjusted proper. I too suspect a world of difference.
  6. Likes Dope liked this post
  7. #24
    Nov 2007
    E-burg MD USA
    663
    7
    125
    Dope Sir,
    Hey you don't 'need' 4140 for that gib screw.. 12l14 or any other free machining steel works just fine. May get you up and running a bit sooner if you any thing like that lying about.
    Hope this helps
    Stay safe
    Calvin B ( 1937 #2L,1905 #2 cincy owner )
  8. #25
    Jan 2016
    Indiana
    117
    76
    42
    Quote Originally Posted by calvin b View Post
    Dope Sir,
    Hope this helps
    Stay safe
    That's a good thought! I happen to have some leaded stock laying around somewhere...hmmmm
  9. #26
    Jan 2016
    Indiana
    117
    76
    42
    Final update: got around to making that gib adjustment bolt and got the machine back together. I was able to take a lot of slack out of the table now that I can actually adjust the gib and also got slack out of the feed screw too. There are adjustable lock nuts on either end of the table that lets you take some/most of the backlash out of the feed screw, I wasn't even aware! The manual I got from svs was very useful, thank you! Thanks to everyone that commented, for that matter, it's been an adventure learning this "new" machine.
    Dope
  10. Likes texasgunsmith, dalmatiangirl61, svs liked this post
  11. #27
    Apr 2004
    Riverdale, Nebraska, USA
    882
    150
    79
    That is a good looking gib screw!
  12. Likes Dope liked this post
