CentexMachineShop
- Jan 12, 2020
- Bastrop
Got this thing from a shop for $400in San Antonio. it appears to mostly work except a horrendous hammering noise while moving rapid lever. Vertical head feed box was removed. Not sure why. Everything looks fine. I adjusted the detent lever and put it back on. Worked fine. Question is about the starting switch. When I hit start the contacts rapidly cut in and out. But when I manually push it together and hold it shut the machine fires up and the contacts hold themselves together. This is an Allen Bradley 3 point contact with a magneto looking coil thing. Is this a symptom of the coil being shot?
Thanks for any advice.
