1943 no3 Cincinnati horizontal
Results 1 to 8 of 8
    Dec 2012
    essex england
    973
    1846
    634
    Default 1943 no3 Cincinnati horizontal
    Hello has any the dimensions for the drive gear that goes in the horizontal spindle for the vertical head for a 1943 no3 Cincinnati horizontal
    Jul 2004
    Houston, TX USA
    29,077
    Very particular. Brochure has interesting statements - if one happens to have this head (K&T had NUMEROUS vertical heads)
    Its HELICAL, meaning it is made for the mating gear housed in the head
    The V Head has the same speeds as the machine - meaning the head and its pair of HELICAL gears and pair of SPIRAL BEVELS provides an overall gear ratio of 1:1
    http://vintagemachinery.org/pubs/2097/16366.pdf
    Dec 2012
    essex england
    973
    1846
    634
    Thanks john I assumed 1:1 ratio
    I ll remove the gear from the head a measure it
    Jul 2004
    Houston, TX USA
    29,077
    Quote Originally Posted by pressbrake1 View Post
    You will also need the center distance head gear to spindle gear - in case the spiral bevels inside are not one to one - then the helicals won't be one to one either
    Dec 2012
    essex england
    973
    1846
    634
    Yes that’s why I hoped someone on here had one. And could tell me the amount of teeth.
    It’s always easier to be told than working it out!4a151b93-f67d-447c-bdb3-a1471ae7f003.jpg
  6. Likes Hobby Shop liked this post
    Jul 2004
    Houston, TX USA
    29,077
    Is this one like the brochure and partially supported by dovetail? If so, you have some nice datums to measure from
    Aug 2010
    AUSTRALIA
    48
    FWIW, a number 2 drive gear is 5.3" OD, has 28 teeth and is 1.5" wide.
    The back of the gear is 1.4" from the column face.
    The driven gear is about 3.7" OD and has 19 teeth.
    Hope this helps.
  9. Likes pressbrake1 liked this post
  10. #8
    Dec 2012
    essex england
    973
    1846
    634
    Thankyou very much for taking the time to measure up
    Pb
