1949 Cincinnati No.3 High Power 4J3P1V need help.
Results 1 to 10 of 10
    Nov 2014
    MALAYSIA
    20
    6
    5
    Default 1949 Cincinnati No.3 High Power 4J3P1V need help.
    I recently came across a Cincinnati No.3 that needs some major repair. Machine is not feeding due to a jammed hydraulic drive shaft. I'm having trouble looking for the correct manual and so far all the manuals that I have found has a different overarm compared to mine (see attached pictures). If someone can point me to the correct manual I would be grateful. Also I found two disconnected pipe fittings on the underside of the knee in feedbox compartment, as shown in the attached pictures. Anyone has any idea what these are for?
    Attached Thumbnails Attached Thumbnails photo_2020-10-18_00-24-42.jpg   photo_2020-10-18_00-24-43.jpg   photo_2020-10-18_00-24-44.jpg   photo_2020-10-18_00-24-41.jpg   photo_2020-10-18_00-24-39.jpg
  2. Likes texasgunsmith liked this post
  3. #2
    Nov 2014
    MALAYSIA
    20
    6
    5
    More pictures...
    Feb 2016
    1,587
    1064
    575
    I think the powered overarm is something of an accessory. It would have its own manual. This one may help for overarm:
    http://vintagemachinery.org/pubs/2097/15295.pdf
    While the parts and service manual are combined here, for #2, #3, and #4 dial type:
    http://vintagemachinery.org/pubs/2097/22565.pdf
    Jul 2004
    Houston, TX USA
    31,706
    If you look on the first real page of the manual (the one after GS10) you will see it applies only to 2A and 4A serials
  6. Likes texasgunsmith liked this post
  7. #5
    Feb 2016
    1,587
    1064
    575
    Quote Originally Posted by johnoder View Post
    Good eye, good eye !
    Here's a service and parts manual for 3J and 4J on ebay, 191 pages:
    Cincinnati Milling Machine # 3, 4, 5, & 6 Mod OD Service and Parts List Manual | eBay
  8. #6
    Nov 2014
    MALAYSIA
    20
    6
    5
    Wow that's a good find on that over arm. Unfortunately the owner replaced the geartrain removed with an inverter.
    The 4J manual on Ebay is a hard hardcopy version though, is there a purchasable soft copy somewhere though?
    On another note, does anyone know what's the HP on the rear bottom motor that drives the main pulley? I've read on this forum it could be anywhere from 20-50HP. That's a monster of a machine if that's true. Also can anyone confirm if the main hydraulic shaft is supposed to turn on motor start up?
  9. #7
    Feb 2016
    1,587
    1064
    575
    Quote Originally Posted by newcomer View Post
    A No 2 is like 7.5 to 10hp. I was thinking a No 3 would be 10 to 15hp.
    Looking at these 3 brochures, there are No 3's with 10, 15, and 20hp.
    10hp:
    http://vintagemachinery.org/pubs/2097/16338.pdf
    15hp:
    http://vintagemachinery.org/pubs/2097/16339.pdf
    20hp:
    http://vintagemachinery.org/pubs/2097/16344.pdf
    If the external power rating data plate is missing, maybe the motor has a data plate.
  10. Likes newcomer liked this post
  11. #8
    Jul 2004
    Houston, TX USA
    31,706
    For what its worth - the most powerful #3 K&T in 1957 was 30 HP - but the "ram" (fancy overarm) had but 15 for the main
    Not exactly applicable since you have the HEAVIEST #3 made that year by CMM
    Just that king size knee says that
  12. Likes newcomer liked this post
  13. #9
    Nov 2014
    MALAYSIA
    20
    6
    5
    The nameplate is located in such a tight space that I'd need an endoscope to read it. The owner is considering to replace it with a new machine but nothing seems to come close to that 70 years old machine in terms of power. Not for a big sum at least. I'm kind of tempted to buy his #3 but that torque destroyer VFD conversion puts me off.
  14. #10
    Aug 2006
    Shelbyville, Ky
    509
    45
    190
    My #4 machine is 25hp on the main spindle 7.5 on the independent overarm.
