1975 16" Reed Prentice a bit too new?
Likes Likes:  0
Results 1 to 15 of 15
    Oct 2009
    Oregon
    4,572
    4925
    2368
    Default 1975 16" Reed Prentice a bit too new?
    I committed to buying a 16X80 RP today and was curious if anyone could confirm this machine was built in 1975. This Lathe looks 40's or 50's, but clear as day it has 1975 stamped into it's headstock ID plate for the build date. Is there anyway to verify the age- Serial numbers or specific features? When did Reed Prentice stop producing machines?
    Thanks for any help.
    Jul 2004
    Houston, TX USA
    30,450
    Serial Number Reference Book For Metalworking Machinery states discontinued in 1966.
    Latest serial in this book is 501230 for 1965.
    John Oder
    Sep 2007
    Washington
    5,317
    209
    1632
    It might have been rebuilt in 1975 (not by R&P).
    FG
    Oct 2009
    Oregon
    4,572
    4925
    2368
    I got the RP home late last night and this morning had the chance to go over the finer details of the lathe. I found a few small federal government looking stamps on the end of the ways and several small riveted plaques in the motor cabinet under the headstock that read "property of the US government Kaiser corporation Portland Oregon"
    These plaques seam to indicate the lathe was used by the Kaiser shipyards here in Portland during WWII. The shipyards were closed after the war. The headstock ID plate is clearly stamped 1975 for date of manufacture, but this must be a restamping from an overhaul. The machine serial number is 23187.
    All in all I'm happy with the condition of the ways and mechanicals. Two cushman chucks came with the Lathe which appear to be 1975 Vintage and were probably replacements during an overhaul.
    This lathe has several layers of paint, the newest brite green, then dark gray with the original appearing as light gray. Would light gray be the appropriate color for this machine?
    Oct 2009
    Oregon
    4,572
    4925
    2368
    I took the carraige apart today. Found a trail of missing parts left by a past owner or rebuilder. I posted a parts wanted ad in the classifieds section http://www.practicalmachinist.com/vb...-parts-202462/
    Attached Thumbnails Attached Thumbnails reedprentice-004.jpg   reedprentice-007.jpg   reedprentice-008.jpg   reedprentice-006.jpg
    Oct 2009
    Oregon
    4,572
    4925
    2368
    A few questions while most of the lathe is soaking in a hot tank-
    1) Can anyone narrow down what year this Reed Prentice was actually made by it's serial number (23187)? I would like to remove the "1975" that's been stamped into the headstock ID plate and re stamp it with the right year.
    2) I need to make new crosslide nuts- What material would be best to use for these?
    3) This lathe is supposed to have two gibbs and a clamp under the carraige to hold the carraige to the ways (these parts are located between the ways on the operator side). These parts are all gone. Any theories on why these pieces wouldn't be re-installed? I think they've been gone since the lathe had it's ways ground in 1975.
    Thanks for any help you guys can offer. I wasn't planning on this lathe being such a project to get it ready to work, but it's great to have a place I can get answers from.
    Jun 2003
    Mebane North Carolina USA
    6,739
    53
    1953
    #2 make from bronze
    Jan 2005
    Victoria, Texas, USA
    4,124
    2346
    1051
    #3. hold down clamps holding the carriage to the bed. A number of lathes i have seen in my past that were rebuilt, the primary clamp on the back side of the saddle were left in place. But the secondary holdown on the front of the bed were generally left off. There's nothing legit for needing them. Don't worry about replacing them, they just collect crud and cause abnormal wear.
    Added Note:
    If you ever get in a situation where the carriage/saddle starts moving up and down or bouncing around, you are fixing to have real problems that a missing hold down is not going to fix! It's called a wreck!
    Ken
    Jul 2004
    Houston, TX USA
    30,450
    what year
    1943
    John Oder
    Oct 2009
    Oregon
    4,572
    4925
    2368
    Quote Originally Posted by 4GSR View Post
    Added Note:
    Ken
    Ken, I thought there might be something more to it. The design of the carraige does chips and crud to accumulate between the vee way and the flat way these extra gibbs ride on.
    Quote Originally Posted by johnoder View Post
    1943
    John Oder
    Thanks again John, I really appreciate your taking the time to look up my serial number.
  11. #11
    Nov 2019
    Colorado
    Can anyone help identify this reed prentice , it has no tags or Name plates on it ? Serial number on the end of the bed or ways is 32621 it’s a 16x60
  12. #12
    Jul 2004
    Houston, TX USA
    30,450
    Quote Originally Posted by W900 View Post
    All the serial tells us is that it was made in 1943
    Thumbnail from 1936
  13. #13
    Aug 2012
    California, Central Coast
    4,044
    2226
    1589
    Your question is like asking "I have an old car, it has 4 doors made is 1972, tell me about it."
    Dude, quit digging up ancient threads and asking the same question.
    Start a NEW thread about you lathe and dont start it until you learn how to post PICTURES of the lathe.
  14. #14
    Feb 2020
    Kentucky
    6
    Where can i run my number at off my reed ? Is there a site u can look it up on
  15. #15
    Jul 2004
    Houston, TX USA
    30,450
    Quote Originally Posted by Bobbyrhamby View Post
    Probably would have heard of it if there was such a thing
    Post the serial and I'll see if I can date it
