30 inch Rockford planner, need to reduce electric load, - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21
    Jan 2005
    The Netherlands
    5,852
    280
    1511
    Copyright expires after 70 years after first publication At least if published by a compagnie
    Otherwise 70 years after the death of the writer
    So it is completly legal to post that information here
    Peter
  2. #22
    Jul 2007
    Missoula Mt
    28
    Swatkins, My pump turns out to be a vickers vain pump not the oilgear in the pics,years ago I scraped a badly rusted 10 ft rockford that had the oilgear, what a heavy beast. I dont know why the little planner has a 20 hp motor the standard seems to be 10hp...Phil
  3. #23
    Mar 2006
    jacksonville,fl.
    1,150
    971
    386
    It's hard to tell on a Govt. machine.Maybe they intended to plane some material that required a faster than normal sfm.Hence the larger motor and pump combo.
    If it were me I wouldn't change anything without trying it first.It will start up with all the oil bypassing and depending on the valve setting will determine the currant draw.Hook a ammeter to it and run it with the discharge port from the valve blocked and adjust the pressure to what ever max amps you need.Just start with the pressure backed all the way off.To hit the FLA of the 20hp set up you would have to operate the machine at the max cut and speed the package was designed for.You may never do that in your use.
    The manuals may tell how to set max pressure.On some balers you can just dead head the cyl and set the pressure to the desired amps.
  4. Likes Paolo_MD liked this post
