Approximate Weight of 3K Vertical Milling Head
Results 1 to 7 of 7
    Feb 2012
    USA, Virginia
    241
    186
    53
    Default Approximate Weight of 3K Vertical Milling Head
    Just wondering if anyone might know the weight of this. I want to remove it to make stripping the paint on both the machine and head easier and just want to know if my cherry picker is up to th task all the way extended out. It says 1/2 ton. Thanks for any info.pxl_20211130_163513122.jpg
    Sent from my Pixel 4 XL using Tapatalk
    Oct 2009
    Olympia, Wa
    805
    345
    259
    Not sure on the exact weight of that head, but I have a 2k with universal head. 2 people can lift that head, I would probably put it at 200-250lbs. I can't imagine a 3k vertical head being that much more. You should be fine with a 1/2 ton hoist.
  3. Likes Ja_cain liked this post
    Sep 2017
    New Jersey
    391
    5
    118
    Quote Originally Posted by Ja_cain View Post
    Probably about 450lbs? Doesn't it look like the one in this book for the 3K?
    http://vintagemachinery.org/pubs/2098/17371.pdf
  5. Likes Ja_cain liked this post
  6. #4
    Jul 2004
    Houston, TX USA
    32,614
    1940 full line catalog says 448 / 460 - as in Post #3
  7. Likes Ja_cain liked this post
  8. #5
    Feb 2012
    USA, Virginia
    241
    186
    53
    Thanks for the info guys. I just haven't had the time to look through the catalogs and figured someone would know off hand. I I might just rig one of these up buy sliding it over the picker to get a little extra extension until I can move it under the beam. Figure it should be ok and will probably ballast the other end with some weight too.pxl_20211129_184800684.jpgpxl_20211130_172144153.jpgpxl_20211129_200205607.jpg
  9. #6
    Apr 2013
    Damascus, MD
    1,724
    5133
    984
    Personally, I wouldn't extend an engine hoist: it's already not very stable by itself, if you extend the arm, you risk tipping it on the side before you realize what is going on.
    Do yourself a favor and buy/build a gantry: you are anyhow going to need it to mount/remove the head in the future and, likely, to put anything heavy on the table.
    Paolo
  10. Likes Ja_cain liked this post
  11. #7
    Feb 2013
    Northern califorina, usa
    452
    13
    177
    We built simple swing arm jibs with chain falls above our larger mills.
    There great for removing/installing the vertical heads, installing dividing heads and loading material onto the bed.
  12. Likes Ja_cain, Paolo_MD liked this post
