Blazemaster
Hot Rolled
- Oct 13, 2009
- Olympia, Wa
I have searched and searched and can't seem to come up with an answer on which bronze to use for this nut. It is for the x axis table nut. I have pretty much narrowed it down to 954 aluminum bronze, or 932 (660) bearing bronze. I have found threads where folks recommend the 932, and others that say only 954 will do. I have also found threads that say 954 is too much and will wear the screw. Does anyone happen to know what alloy K&T used?
I managed to remove the old nut, which was not easy. I have never seen 954 that I know of, but I have a chunk of 932 that I bought a while back to make a bushing and thought I would compare the two. The K&T nut looks more red to me.
I am sure either will work from their descriptions but I would like to use the right material. They are roughly the same price.
I would also like to find someone local to help make this nut for me, if possible.
Thanks!
Thanks!
