thmachine1
- Oct 30, 2016
Hello,
Through the help of PM, and willing participants. We have helped reverse engineer, and fabricate replacement drive gears for those who have a vertical head attachment. Currently there are 5 gear replacements for the various style vertical heads & machines, and even including a slotting head driver.
If you are one of those individuals who are missing a drive gear, feel free to reach out, and we will do our best to assist. Right now there is a solution for, but not limited to:
2HL - Heavy Duty Universal Milling Attachment (32 tooth driver - 32 tooth driven)
2HL - Heavy Duty Vertical Milling Attachment (38 tooth driver - 26 tooth driven)
2HL - Std. High Speed Adj. Universal Milling Attachment (24 tooth driver - 23 tooth driven)
2H - Std. High Speed Adj. Universal Milling Attachment (30 tooth driver - 24 tooth driven)
2K&3K - Std. High Speed Adj. Universal Milling Attachment (35 tooth driver - 21 tooth driven)
3CH - Slotting Head Attachment (Driver)
Couple of common FAQs:
These gears are not hardened, and will be made out of HR1045 Steel unless specified.
Happy to share the reverse engineered calculations for each gear set to help determine the right fit.
These gears are manufactured on a horizontal mill with dividing head & leads attachment, and not made on a gear hobbing machine.
Thanks! Here to help.
