Cinci Monset grinder age?
Results 1 to 6 of 6
    Jul 2004
    Reddington, N.J., U.S.A.
    3,425
    295
    329
    Default Cinci Monset grinder age?
    Have been looking to buy a Monoset grinder. One has come up for auction near me, haven't been able to see it in person to check for collets and attachments yet. Can't see the model# in the posted images, but the posted serial number is: 201CSL-39. Any way to determine its age from just the SN? When I'm able to inspect the machine, what are the key areas to check? One thing that immediately jumps out at me is that this machine and several others in the auction have all been repainted.
    Jul 2004
    Houston, TX USA
    31,250
    1962 if the "S" is actually a FIVE
    I.E., date code 5L
  3. Likes reggie_obe liked this post
    Nov 2007
    marysville ohio
    10,074
    2858
    6738
    Quote Originally Posted by reggie_obe View Post
    Make sure all the collets and small parts / stops / stone holders / odds and ends are there, the thing is worthless without all the bits and you will NEVER find them. Ask me how I know.
  5. Likes reggie_obe liked this post
  6. #4
    Jun 2012
    Michigan
    12,131
    4097
    4348
    Here is the manual for the Monoset but not much info in it.
    http://manuals.chudov.com/Cincinnati...der-Manual.pdf
    Good to download the Cincinnati #2 manual to find cutter sharpening methods that most can also be done on the Monoset.
    A good tight Monoset can pick up a spiral. With not much tooling one can put a 4jaw in the work hear end and do many kinds of tooling, Yes with having taper shank holders ground straight to fit the 4jaw for taper shank tooling and for holding a straight arbor for mill cutters and saws....
    Yes above suggestions to make due with not having all the do dads Moonlight is talking about that are hard to find/ or priced like gold..
    I used to run a Monoset at the big shop.
    I think a Cici #2 or the like (with tilt work head and centers) is handier for general sharpening..but the Monoset can swing corner radius and pick up a spiral(if it is a tight machine) .
  7. Likes reggie_obe, Cal Haines liked this post
  8. #5
    Jul 2004
    3,425
    295
    329
    Quote Originally Posted by johnoder View Post
    I.E., date code 5L
    Yes, the S is actually a Five.
    Thanks to all that posted advice. The machine is bare bones, missing: collets; dresser; tooth rest; tailstock; etc.; etc. Not worth considering. There are better machines out there.
  9. #6
    Jun 2012
    Michigan
    12,131
    4097
    4348
    Thanks to all that posted advice. The machine is missing is bare bone, no collets, dresser, tooth rest, tailstock, etc., etc. Not worth considering.
    Some things can be found on ebay...so depends on your intentions.
    https://www.ebay.com/sch/i.html?_fro...monoset&_pgn=2
  10. Likes Cal Haines liked this post
