I just picked up this Tool Master.
http://www.practicalmachinist.com/v...-heavy-iron/new-cincinnati-toolmaster-252238/
This is one stout milling machine! Who said Bridgeport....
I am having issues with the hydraulics in the knee (Cinel 60 202-12hv). When I turn it on, the hydraulics run at normal speed, but after a minute or so it ramps up to higher rate about the same as if in rapid traverse. I can't find any adjustment screw. Also, the rapid traverse lever does not work. I can pull it up and nothing happens. I was going to pull the plate that the rapid traverse lever is attached to, but I don't feel like pulling it and hearing something let loose and not knowing what it was.
Anyone have any idea of how to adjust or fix the issue?
I also pulled the brake lever off the head, it is metal on metal. Are there any replacement brake pads or is there a specific material to use to remake the brake pads.
Lot of little issues to sort out on this, but the vertical head is up and running. I need to wire up the horizontal side, I have push button switches, run, reverse, and stop that I will use. Oil leaks underneath the knee I need to seal up. Already repaired a number of items on it.
Overall I am pleased with the mill, just needs attention in several areas.
