I spun the head around so that I could put the quill in from above, but it is going in the correct way. I only heard it run once but it sounded ok at that time. I did not feel it for heat, but he has never run it very long anyway. I believe he has the correct service manual, but since I don’t have access to a computer at this time I can’t be positive. It sure would make things easier... just to verify, shouldn’t the quill slide into the head with hand pressure alone? Jim
Right, if the quill isn't a slip fit into the head casting, then it won't be able to slide up and down when in normal use.
Either there are part(s) in the way (something not removed during disassembly?), or a burr or some grit. Does the OD of the quill or the ID of casting bore show any evidence of scoring?
Just to be clear on what is happening, when you try to insert the quill into the bottom of the head casting, how far in will the quill go before it binds? Will it even start in the bore?
Since you don't know the history of this machine, don't overlook the possibility that someone has been into it before and buggered things up. For example, I'd verify that the parts on hand are the correct ones. Cincinnati was very diligent about stamping their part numbers on almost every part, so you should be able to check that the parts in hand match the catalog. The factory made some changes to these machines over the many years of production, and it's not impossible that someone tried to make later parts work in an earlier machine. I don't know the changes (if any) within the 1-B head over the years, but I have an early 1-B with the power feed on the X-axis, and when I opened up the power feed gearbox to make some repairs, I discovered that some of the parts were from a later machine, so it's not unheard of.
I know you don't have pics, but if there's any way to post them (or email them to me and I'll post them) or get someone to take some pics for you, those would be really helpful.
