Hello All,
I got a question I think I know the answer to, but I wanted to hear your thoughts as well.
With the clutch DISengaged, my table/saddle/knee will slowly adjust if I engage their feed handles. Is this due to a sticky clutch or some other situation, like a gummed up system? I was leaning on sticky clutch. If so, can this be remedied from the outside or will I need to remove the drive assembly? I'm having the manual printed for easier review.
For a little additional fun, I pulled the motor because it was pulling 8.5 while idling, 6 amps without belts and 11 while turning the spindle. Bearings had about 0.04 inch of axial play and rattled like a bag of beads when I shook them. The motor was also pretty gummy too.
Thank you!
Thank you!
