Cincinnati Greaves Mill question
Likes Likes:  0
Results 1 to 9 of 9
    Feb 2013
    Northern califorina, usa
    423
    9
    156
    Default Cincinnati Greaves Mill question
    We purchased a Cincinnati Greaves universal mill from a university lab that appears to have never been used or used very little, In other words it looks brand new. It came with a Greaves dividing head that has a drive set up on it.
    We were told that the dividing head and vertical head were all purchased new at the same time as the mill.
    Apairently in the 40 or so years that the mill languished in the corner of the lab parts of the dividing head drive system disappeared. The mill came with a complete parts manual and service manual, however neither manuals have any information on the dividing head drive. There is only a picture of the head mounted to the table.
    This is the model Greaves universal that has ONE drive motor for all functions.
    Question is there anyone out there that has any photos etc related to the driven dividing head.
    We did get some random spur gears with it, and there is a arm and idler mounted to the dividing head itself.
    We have a couple of K&T mills and a Cincinnati mill with driven dividing heads and basically there pretty much the same. I would just like to see how the Greaves was originally set up.
    Feb 2016
    2,138
    1521
    921
    Can't answer your specific question. But that mill would be quite a bit older than 40 years.
    Not a ton of info, but a little history of Greaves Machine Tool Co:
    Greaves Machine Tool Co. - History | VintageMachinery.org
    Only 2 publication reprints on VM, undated but look like 1940's:
    Greaves Machine Tool Co. - Publication Reprints | VintageMachinery.org
    Jul 2007
    Missoula Mt
    1,421
    62
    702
    I have the newest of the grieves, 1971, your is a lot older than that, the new one have a motor in the knee, old one have drive shafts like yours, anyway the missing parts would not be hard to make...Phil
    Feb 2013
    423
    9
    156
    Yes, I have seen all those. Just attempting to find someone out there that had or has a Greaves with the driven dividing head.
    Fabricating missing pieces should not a problem for the most part, it would however be nice to see how Greaves set up the drive system so we are not re-engineering.
    The original invoice for the machine has a date of May 5 1964
    Jun 2021
    Washington
    I also just picked up one of these machines and am looking for the dividing head for it if anyone has an extra.
    Feb 2013
    423
    9
    156
    Are you looking for an actual Greaves dividing head that is driven or just a standard dividing head that is the correct size for your table.
    Jun 2021
    Washington
    Quote Originally Posted by dana gear View Post
    A dividing head with the gear drive
    Jun 2021
    Washington
    The actual Greaves dividing head.
    Feb 2013
    423
    9
    156
    I been in this business my entire life, actually my family been involved with machine work since around 1918. That said in all this time I have only seen 5 Greaves driven dividing heads ever, and two of those I own. Although both of these are missing the Greaves factory drive assembly. We ended up fabricating a drive system for one of ours.
    I do believe that there are far more Greaves mills back east then out here in NorCal .
