oceanobob
- May 18, 2014
- Oceano, CA
Happened upon a horizontal mill manufactured by Cincinnati. Am limited in knowledge and information - the 'deal' is being made by way of this picture where it can be seen the handle is broken (at what I perceive as a speed changer).
Tooling is limited to a few cutters.
If someone can indicate the likely model, I would appreciate very much.
Should I inspire myself to obtain a vertical head option? I have a Diamond products mill and it is horizontal and came with a vertical head option that has come in quite handy. This Cincinnati should be a good second horizontal mill for those larger items.
I have read where Cincinnati had developed a reduced backlash setup on the feed where it could be possible to do some amount of climb milling without causing problems - by any chance is it the opine this machine would have that feature?
Scheduled to haul it about 40 miles this coming Saturday - will update this post with more pics once it is in my shop.
With kind regards....
