sliverr2
- Nov 30, 2013
- rhode island
Looking for some help in solving what i think is a problem with my hydrashift.recently acquired it and found that the quickchange gear box was put together wrong. i straightened out that but now notice the speed feed tag does not match the actual speed and feeds.Example- if i select a 3 pitch the lead screw turns slower than if i select a 5 3/4 pitch. the tag is the correct part number for the hydrashift 10 so i am wondering if the gear box is from a differant machine.the tag part number i have is 607079 which is correct by the parts book for a 10.anyone able to supply me with pics of tags with part numbers 607078 and 607079? this will help me either solve or eliminate one possible reason for this problem. to add to this my gear box is a 54 speed the book says that is what a 22 and 26 lathe has and i assume i should only have 48.
