Elwood1968
Cast Iron
- Jul 30, 2017
I'm replacing the spindle bearings on my Cincinnati Hydrashift 12-1/2" x 36" manual lathe, but have some issues that hopefully someone here with more bearing knowledge can chime in on.
First, some background:
1. The spindle bearing setup is a box design, i.e. three bearings total: two opposing tapered roller bearings, one at the nose, and one in the middle of the shaft, with a deep-groove, single-row ball bearing at the left end. The middle tapered roller bearing is set axially with an adjustable locking collar nut, which controls the pre-load on the two roller bearings. The ball bearing is fixed to the spindle, and essentially "floats" axially in the bore in the headstock, allowing for thermal expansion of the spindle. Here's a drawing of the spindle from the Cincinnati factory manual and parts catalog:
2. This lathe is an earlier machine, built in 1963 (I think), s/n 1W295M-23. It is the standard model, not the toolroom or 3,000rpm version. The spindle rpm range is from 26 to 1,800 (two-speed motor).
4. Spindle bearing lubrication is by a low-pressure oil pump with distribution lines from an un-regulated splitter block to the individual bearings. Lubricant is Mobil DTE Light. Oddly enough, the left end ball bearing on the spindle does not have a lube line, so it must rely on splash lube.
5. Cincinnati did not give specifics on the spindle bearings in their manual, only referring to them by their factory part numbers, but I'm assuming that the different part numbers for the tapered roller bearings (callouts 8 and 13 above) in the standard lathe versus the toolroom/3,000rpm lathe models implies a higher precision rating for the latter.
6. When I pulled the spindle from my machine, the tapered roller bearings looked to be the original Timkens. In addition to the usual "TIMKEN" and bearing numbers stamped into the race, the cone on the center bearing was ink stamped "163" and "3", which I'm guessing means a January 1963 build date, precision Class 3. The cone on the right bearing (next to the spindle nose) was similarly ink stamped "262" and "3".
7. The ball bearing had probably been changed at some point in this lathe's life, based on the marks on the mounting sleeve on the spindle. What I removed was an NDH (New Departure Hyatt) 3212, which is a standard 60mm x 110mm x 22mm size. Other than the "3212" and "NDH", it was unmarked, so I'm assuming it was ungraded, probably ABEC 1, and likely not a precision bearing. This one also had a seal on one side, which I suspect is incorrect given the oil flow path in the headstock.
I've been able to find replacements for the two tapered roller bearing cones and cups, which is something of a relief as the middle bearing cone is a "W" suffix, meaning it has a notch ground into the ID for a taper key to lock it to the spindle shaft, and I didn't relish the idea of grinding my own notch into a plain ID bearing. The middle bearing cone and cup are Class 3 like the original. The right end matched cone and cup bearing set that I found is Class 0, so one precision grade higher than original.
Here are my concerns:
1. Will mixing precision classes between the bearings be an issue? One potential problem is that the Class 0 bearing is marked for the high spots, but the Class 3 bearing is not. So there's no way that I know of to align the two bearings to minimize the runout. Or is there?
2. Cincinnati shows different part numbers for the left end ball bearing between the two lathe models, but they didn't show any specs as to the precision class. Should I go with an ABEC 5, or is an ABEC 1 acceptable? My inclination is to go ABEC 5, despite the significant cost difference, but a three-point box mounting is a much more complicated dynamic assembly, and I'm not sure how increasing the precision class (i.e. reducing the radial runout) at that end will affect - good or bad - the spindle accuracy, harmonics, bearing life, etc.
3. The Timken website has some great technical resources, and I've been wading my way through it, but I can't find any information about bearing break-in with oil-lubrication. Timken has a section on the break-in process for grease lubricated tapered roller bearings, but makes no mention that I can find for oil-lubricated. The original Cincinnati manual does not mention it either, other than to change the headstock lubricant after the first 60 days of operation.
I contacted Timken technical support last week to get their input on these questions, but have not heard back, so either I'm down the priority list (understandable), or they're just slow with these inquiries.
