cdhthethird
- Nov 26, 2020
Does anyone know what the dimensions of the two gears to convert my LR to cut metric threads? Per the repair manual it mentions one gear is attached to the idler shaft which has a 120 tooth gear from the factory so I assume the conversion gear is a 127 tooth. However I need the dimensions for the gear that replaces the one on the lead screw. Also I would hope someone has a photo of the thread index plate for the Quick Change gear box.
I really appreciate any help and thank you.
