We have an old Cincinnati Milacron at the plant. It's designed to run on 240 to 480 VAC 3 phase but we are running it on 208.
We've had some interment problems with it which are probably caused by the control transformer putting out only 105 - 108 volts because it's not designed for a 208 volt input.
Our 208 is 120 to 123 volts leg to ground and about 209 volts leg to leg. Is there any reason why I can't leave the control transformer out of the equation and just power our control's 120 volt needs directly from my incoming 120 volt ac power?
