Small Cincy mill on Craig’s list.
Miguels244
Mar 27, 2011
Denver, CO USA
Not mine, dunno the seller...now with working link.
What’s this?
Cincinnati Milling Machine - tools - by owner - sale
If he cared to do a little cleaning of green overspray on the tag, we could read the serial
Basically, a PRODUCTION mill intended to make the same cut on many of the same part for years if needed
In no way a versatile, handy milling machine
Cincy built these with CHANGE GEARS for such ordinary functions as feeds and speeds - an indication of their non versatility
Much like the 08 vertical they produced.. Used in banks, each one with a specific setup to do one step of a milling process...Very rigid but terribly limited in versatility....The 08 I had came from Browning Arms probably used to mill a certain slot in a pistol frame or some other part of a firearm....Terrible choice for home shop as I soon discovered.. Ramsay 1:)
C Mike
The best I could fine is a manual with copy right manual of 1940 of a 0 - 8. The hand crank at the end of the table is interesting. Can't fine any thing showing the crank. It does have a cam cycle under the little door.
The best I could fine is manual with a copy right of 1940 of a 0 - 8. The hand crank at the end of the table is interesting. Can't fine any thing showing the crank. It does have a cam cycle on the front under the little door,
