Cincinnati power feed problem help please
Likes Likes:  0
Results 1 to 5 of 5
    Feb 2011
    UK
    35
    Default Cincinnati power feed problem help please
    Hi Has anyone any experience with a Cincinnati no 2 universal mill, I have no power feed or rapid traverse, I have had this problem before and reconditioned the oil pump and would work, But this time nothing, I haven't checked the oil pressure as yet as I need a 500 psI gauge, I have ordered one and waiting for it to come in, I have put the complete pump / side plate on it from a good running machine but still nothing, The gears just grind but dont seem to select, AndI have noticed that the good machine has the shaft that goes in to the rapid travers turing and on the mache that has no feed it is not turning, If you try to turn it by hand it turns slowly for a bit and stops.
    Any help would be much appreciated.
    paul
    Jul 2004
    Houston, TX USA
    29,485
    Might help to say WHICH #2. They started making mills in 1884
    Feb 2011
    UK
    35
    Hi Think they call it the MI series. Serial number 2J2U6KE,67
    Paul
    Feb 2011
    UK
    35
    Hi I have now tested the oil pressure from the middle grub screw next to the oil pump, And it is zero. I know it is not the pump a i have put a complete side plate and pump assembly from my other good running machine, and still no feeds , Can anyone tell me where to look next please.
    Paul
    Feb 2011
    UK
    35
    I found the problem , a pipe had come off, now I have over 500 psi oil pressure and the relieve valve adjustment makes no difference whatsoever, the dump line must have a problem, but I cant find any information as to how this works, a drawing would really help if anyone has one. of any advice please
    Paul
