Cincinnati Toolmaster questions about collets and lubrication
Results 1 to 12 of 12
    Jul 2018
    Nevada
    5
    Default Cincinnati Toolmaster questions about collets and lubrication
    I have recently acquired a Cincinnati Toolmaster mill, I believe it to be a 1B from pictures online. It didn’t come with any proper collets, instead had a 5C collet with the threads cut off and a crudely made bushing. What is the proper direction I should go about tooling? Is there a way to make these 5C collets work or does anybody make an adapter for ER40 collets?
    A manual that I found online has way oil as P-55. What does this crossover to now? I believe it’s the heavier Vactra 4 ISO 220, is that right? Also is there gearbox oil in the head that I should change?
    Thank you in advance for your help!
    -Tom in Vegas
    Aug 2015
    Illinois
    1,490
    1092
    635
    If it uses the same collets as the old Contour Master mills the taper is identical to the 40 milling machine taper. On my Contour master I used a 40 taper endmill holder, turned down the flange part way and made a special nut to retain the holder. That could also be done with a 40 taper ER collet chuck.
    Aug 2007
    Rhode Island
    282
    30
    54
    Quote Originally Posted by Taltruda View Post
    -Tom in Vegas
    Send me a pm and I will send you a digital operator and maintenance manual, they use a 3CH collet which are available on eBay and new from Hardinge
  4. Likes Taltruda liked this post
    Jul 2018
    Nevada
    5
    I think Jeffers is right with the 3CH collets. I heard other Cincinnati mills do take the 40 taper, but I don’t think this one does. Thank you for the reply though!
    Nov 2007
    E-burg MD USA
    581
    97
    Tom Sir,
    p-55 = mobil dte medium ISO 46 Just for future reference Mobil industrial tech supports # is 1-800-662-4525. They will be more than happy to cross reference any obsolete oil/lubricatnt you may come across.
    Hope this helps
    Stay safe
    Calvin B
  7. Likes Taltruda liked this post
  8. #6
    Dec 2013
    Vermont, USA
    458
    6
    113
    Assuming you do indeed have a 1B the collets are often called "monoset" collets; Hardinge does make them but remain seated when you look at prices, they are very expensive. One solution, and what I did, was to get one monoset collet (1") that let me put a straight shank ER40 collet chuck in the Toolmaster. The 'tolerance stacking' of multiple interfaces is usually something best avoided, but I got a Maritool ER40 chuck, which is at least one of the much better made ER chucks; I just couldn't swing or justify a full set of the Monotool collets at north of $150 each.
  9. #7
    Feb 2005
    Ohio
    1,204
    1373
    215
    Search ebay for "Cincinnati Monoset" and you'll find many examples.
    Mike
  10. #8
    Jul 2018
    Nevada
    5
    Thanks Calvin, I’ll call them on Monday. I thought I read somewhere that p-55 has a viscosity of 200-220, which is close to Vactra 4 type way oil.. BP type machines use a lighter vactra 2. I’m in Vegas, so the heat will thin it some..
  11. #9
    Virginia
    30,565
    7561
    9538
    Quote Originally Posted by kd1yt View Post
    +1 Could also consider a MariTool TG if you can use the "tail". Work of art, I'd class 'em.
    TG collets are inherently half the collapse range of ER, which makes no never mind if using but a few sizes rather than a "set" and gives better grip for just about exactly the same amount of cleaning prep and torque-wrenching nuisance as ER.
  12. #10
    Nov 2007
    E-burg MD USA
    581
    97
    Tom Sir,
    Well "200-220" would be close to vactra #4 if the p-55 spec was using the ISO scale instead of the older saybolt universal seconds @ 100° F scale... Try this link for an explanation.. Comparative Viscosity Chart Anyhow Give the nice people at mobil industrial a call and they will hook you up with what you need.. Personally I'd go with vactra# 2 for your way oil needs but that's just me..
    Oh and congrats on getting the cincy.. great machine from a great company.
    Hope this helps
    Stay safe
    Calvin B
    PS you mentioned oil in the head.. well for what it's worth when I gets me mitts on an new-to-me machine I change every fluid I can so I know what's in said machine..
  13. #11
    Jul 2004
    N. GA- 33.992N , -83.72W usa
    3,823
    70
    892
    just use vactra 2 or equivalent on the ways. i use chevron vistac , it's 1/2 the cost
    and is sticky like the old vactra . if you put that vactra-4 in the table, you're
    sure to have sore arms crankin' the thing.
    the quill is going to leak all over the place anyway . doesn't matter what you put in there.
    the collets are 3a, and i used to make a tg-100 adaptor and nut for the 1-b.
    i'll have to look and see but i may have one somewhere.
    let me know if you need one.
  14. Likes Taltruda liked this post
  15. #12
    Jul 2018
    Nevada
    5
    Thank you, I'll return the #4 and get the #2 equivalent. It was $30+ a gallon, but I bought the 5 gallon pail for $75. Let me know if you have a tg-100 adapter, that would be awesome!
    -Tom
