Cleaning up a VN22LU
Results 1 to 8 of 8
    Sep 2017
    New Jersey
    127
    34
    Default Cleaning up a VN22LU
    Hi,
    Just finally picked up my new to me VN 22LU, and have
    Started cleaning it up. It seems in great shape but needing
    At minimum a thorough cleaning and maintenance.
    Some questions are coming up that hopefully people can help with?
    - the feeds motor has an oil slinger which is supposed to lubricate the chain. I assume but canít tell whether this oil reservoir is isolated or connected
    to the machine base coolant sump. Would seem crazy to have them joined, just checking. Iíve pumped 5gal of cutting oil out of the base and a big pile of chips. Iím probably going to clean the coolant sump thoroughly and leave it dry for now.
    - I removed the main motor and pulled it apart, because it was caked in dirt internally. It seemed to run well enough though. A large amount of grease packed in behind the bearings, so they werenít dry. I will clean the bearings at minimum... any preferences on keeping the originals vs replacing with shielded / sealed?
    - the feeds motor says grease every 3years, and says refer to some card for directions which is likely missing for 70years. These are Westinghouse motors it seems. Anyone know the procedure? There are no obvious zerks. Not clear if that motor must be removed to grease?
    - coolant motor seems to be a GE. Manual doesnít say much about it, and any motor spec tag is gone. In case I want to keep it, anyone know the electrical specs? It probably hasnít been run in 30-40years because there is a screw blocking the coolant power switch on the control panel.
    Thanks!
    Phil
    0215ddb6-3375-4857-9d9b-2aaf82978610.jpgfd6bbb90-7328-44b0-922a-b70b8b09618c.jpg53cdf69e-fa58-4c27-8559-df5cdc8d8884.jpged2487c4-795c-457d-8704-6fa9996b2dcf.jpg
    Oct 2010
    Oregon
    5,034
    4236
    1814
    For the main and feed motors, I would keep the existing bearings unless you find actual damage. They're not like spindle bearings that would telegraph irregularities into the work. Since there is no idea what type of old grease was last used, I would completely clean/flush all traces of old grease and then lube with any modern electric motor grease.
    Apr 2004
    Riverdale, Nebraska, USA
    800
    102
    47
    Typical old motor will have two plugs per bearing-remove both , replace one with a zirc and stop pumping when clean grease comes out the open hole. If there is only one plug or zirc one or two pumps is plenty.
    Iíd replace like with like if necessary.
    Been a while since I owned a 22, but surely the feed chain has its own reservoir.
    Scott
    Sep 2017
    New Jersey
    127
    34
    Quote Originally Posted by svs View Post
    I’d replace like with like if necessary.
    Scott
    This is the back of the feed motor.
    I scraped off the years of muck and indeed there's a flathead plug screw
    there... just need the right zerk. There's only one on the top though, and
    given the thing probably hasn't been greased in 35years or so, I may need
    to pull the motor out and clean the bearings...
    Phil
    Oct 2010
    Oregon
    5,034
    4236
    1814
    I strongly recommend that you do pull the motors apart to clean them out. Trying to purge old hardened grease by pushing it through with a surplus of new grease is seldom as successful as you'd like, and incompatible thickeners between the old and new greases can cause some truly unholy messes.
    Sep 2002
    Arizona
    3,583
    799
    473
    Over greasing electric motors is a big problem. Some outfits remove the Zerks and plug the holes to keep over zealous maintenance workers from pumping so much grease into the motor that it can be a fire hazard. Here's what the main motor on my VN No. 16 looked like:
    Note the brass plug that should have been removed each time the motor was greased. Instead, the excess grease got pushed into the motor, getting dangerously close to the windings.
    I agree, pull the motor apart and completely clean out the old grease. Regrease it with a modern synthetic grease like Mobilith SHC 100 and put the plug back. You DO NOT need to repeatedly grease the motor.
    Cal
    Dec 2015
    Connecticut
    774
    22
    236
    I just recently found a great chart that shows how much grease per bearing by bearing size. The bearings on my 3hp knee mill 6205/6206 need
    .12 and .15 oz . I weighed the grease on a 150gram electronic scale and it was 7 pumps for the .15oz
    Many motors have the bearing size on the name plate.
    The part I found amazing was at 3600 rpm it only needs grease every 8000 hours, thatís 4 years at 8 per day
    I have the link at work if anyone cares
  8. Likes sfriedberg liked this post
  9. #8
    Sep 2017
    New Jersey
    127
    34
    Default Van Norman 22L knee sheet metal?
    Hi,
    Progress report... pulled both motors, cleaned bearings and re-greased with Mobilith grease.
    Test ran them on the VFDs (will be one per motor, 2hp each) and they seem to run nicely.
    It turns out the main motor casting has a hairline crack in the casting at about the 12o'clock
    position (top) which became apparent when I stripped the paint. Not sure if it is worth repairing or not, since the two endbells effectively reinforce across that joint anyway.
    Two new questions:
    However, I found interestingly that the knee's top surface (v-way mating to universal saddle) seems to have a sheet metal layer on top of the base casting, clamped on at the front. Is this normal? It isn't present in the drawings I have from the manual.
    Second, this is the cutterhead on the machine:
    I've drained it (and the knee, and the ram), filled them with diesel and let them soak
    and run a bit. However I'm wondering about whether I should clean the grease out
    of the spindle bearings, or just re-grease them? It isn't clear what kind of grease the
    prior owner was using, so not clear how compatible the greases would be.
    The manual I have doesn't match this mill exactly, so I'm not totally sure what kind of
    bearings these are, and whether I should leave them alone or remove and clean.
    Phil
