Picked up this machine a few years back. (thread link) It's always had an issue where the VFD will trip on over-current when cold-starting the spindle if A) it's cooler than say 60degF in the shop and B) the variable speed head is in high gear, or wound to a high speed in low gear. Once the spindle is warm, over-current does not trip on normal starting.
I bought a service manual with the machine back then, and the lubrication diagram is not a perfect match for my machine. Where the manual describes a grease zerk, this machine has a factory oil cup with adjacent factory placard specifying oil type. This is off to the right hand-side of the variable speed crank handle on the top of the head.
There is also what I assumed was a grease zerk normally hidden under the sheet metal cover of the pancake motor, that is not mentioned in the service manual. Does that look like a grease zerk? I've read recently about fittings that look like grease zerks but are meant for pressurized oil fill.
With cover installed.
General view.
Motor name plate.
General view.
Motor name plate.
