Heavy Duty LeBlonds and Their Rigging
Results 1 to 14 of 14
    Jul 2004
    Houston, TX USA
    30,028
    Default Heavy Duty LeBlonds and Their Rigging
    Do you need to detach the motor mount casting from bottom leg before moving machine?
    24" X 48" 13,000 pound from early forties
    Sep 2015
    ALAND ISLANDS
    38
    10
    7
    I would
  3. Likes Matt_Maguire liked this post
    Apr 2006
    Manchester, England
    8,369
    1234
    5318
    Given the small amount of work involved in removing it I would also.
    Regards Tyrone.
    Oct 2009
    Oregon
    4,300
    4610
    2203
    Depending how it is attached you might leave it. I have a big CNC lathe where the 80HP motor is outboard of the headstock. The motor mounting platform is a piece of 3" steel plate about 36"x36" and bolted to the base casting with 4 approximately 1" bolts. The lathe weighs 20K lbs and that plate supports lifting the machine with jacks no problem.
    Jul 2004
    Houston, TX USA
    30,028
    Thanks men for commenting
    Apr 2013
    Damascus, MD
    1,433
    4143
    808
    If the base is monolithic, removing the motor won't help much and would raise the center of gravity.
    Paolo
  8. Likes rj1939 liked this post
  9. #7
    Mar 2005
    Kansas
    7,573
    438
    3493
    That has got to be the heaviest 24 x 48 lathe I have ever seen mentioned outside of turret lathes.
  10. Likes DrHook liked this post
  11. #8
    Jul 2004
    Houston, TX USA
    30,028
    Quote Originally Posted by gbent View Post
    A few photos. I was not quick enough on the trigger at $450.00 (first listed at $3K). It was real tired but actually ran. Thought I was going to give Walter his first order for a L3 hook spanner
    '48 spec sheet (thanks Mister Honey) says 14940 Lbs for the somewhat later 25 X 48
    It had nothing for tooling except the mounted 3 jaw. It was a few years too early to have the scabbed on hard ways
    Attached Thumbnails Attached Thumbnails 00q0q_7hh1vyximje_1200x900.jpg   00u0u_gxzovvrv47x_1200x900.jpg   00l0l_ipxeuu3tuoc_1200x900.jpg   00909_lh4apfimnwz_1200x900.jpg   leblond_1948_2.jpg
  12. Likes DrHook liked this post
  13. #9
    Apr 2006
    Manchester, England
    8,369
    1234
    5318
    As we used to say over here - " That's a man's lathe ".
    I'm always intrigued to see that big lathes in the US still had the slot in the compound to carry the old lantern style tool post. UK lathes of that ilk would usually have a fixed four way indexable tool post that was designed to be an integral part of the compound.
    Regards Tyrone.
  14. #10
    Jul 2004
    Houston, TX USA
    30,028
    Default Nice Home Shop Size From 1953
    Amazing. The geared / belt driven Heavies were derived from the Dual Drive series - which has to say something good about the DD idea
    This one takes it a step further - only a few gears in the head stock and a 125 HP DC motor driving. Check out the amps.
    17,000 Lb go getter
    LeBlond Heavy Duty NK 32" x 84" Lathe | eBay
    The 32" was at least 34" actual over the ways
    ph
  15. Likes DrHook liked this post
  16. #11
    Virginia
    27,611
    7561
    8598
    Quote Originally Posted by johnoder View Post
    Absolutely. Motor, belts, and guard as well.
    - It is a "lever arm" looking for an excuse to do harm.
    - It isn't that hard nor time-consuming to remove nor re-attach.
    - It has benefit, not detriment, to clean-up, refurb, confirmation of proper alignment, going forward to PROPER re-assembly after long years of ..... who could even know just-what?
    - it makes movement and tiedown easier.
    What's not to like about that "package"?
  17. #12
    Feb 2005
    Ohio
    1,188
    1293
    207
    17,000 Lb go getter
    The Carboloy tag may be a clue that this was a cemented carbide test lathe from the Carboloy lab.
    Kennametal had a similar, but newer 125HP LeBlond in their Latrobe PA. test facility.
    Mike
  18. Likes Paolo_MD liked this post
  19. #13
    Jul 2004
    Houston, TX USA
    30,028
    Goes right along with the very high slowest speed of 42 = 265 SFM on 24" dia
    Quote Originally Posted by mister honey View Post
    Mike
  20. #14
    Aug 2018
    Illinois
    38
    Saw that Carboloy tagged Leblond machine a while back and was a little mistified about that motor. The test lab comments helped to clear the cobwebs. Based on the listing its unclear if the DC drive system for that motor/lathe is with the machine. Might be a little on the expensive side to try to replace that. Otherwise it would be quite the chip maker. That listing has been posted for a Loooong time.
