Hi All,
I have what I believe is a Cincinnati No 2 work head. The published info I can find shows that it should have NMTB 50 taper. the work head has a draw bar with what appears to be a 1 inch 8 TPI male threads. There is a collet in the work head that fits 1-1/2" dia stock. this collet does not have a 50 taper, so there must be an adapter in the work head to adapt from 50 taper to what ever this is. I will look when I get back home.
Any idea what this collet is?
- female 1x8 threads
- 6 inches overall length
- 1-3/4" body diameter
- 2 inch large end of taper dia
- shape similar to R8, but much bigger
I have a crude drawing, but can't figure out how to attach it???
thanks for the help
added the pic. Note the threads are internal (it is just a poor drawing)
thanks for the help
