How to lock the saddle on a 1941 Cincinnati No 2?
Results 1 to 12 of 12
    Jan 2016
    Indiana
    213
    118
    57
    Default How to lock the saddle on a 1941 Cincinnati No 2?
    I feel pretty foolish asking this but this machine is new to me and I can't figure it out. There's a large lever on the lower right of the knee that locks the knee, there are two hex bolts on the front of the saddle that locks the table. But for the life of me I can't figure out the saddle. I don't see any obvious levers or bolts anywhere.
    I've googled it and checked the manuals and don't see anything useful. Help a newbie brother out
    Feb 2016
    2,266
    1593
    984
    Not exactly your mill but check this pic, do you have this lever ?
    From this brochure:
    Cincinnati Milling Machine Co. (Milacron) - Publication Reprints - Cincinnati Dial Type Milling Machine Specifications Brochure | VintageMachinery.org
    the pdf:
    http://vintagemachinery.org/pubs/2097/19877.pdf
    Edit: Apologies, but I had to edit title for search purposes.
  3. Likes Matt_Maguire, 4GSR, Dope liked this post
    Feb 2016
    2,266
    1593
    984
    I was thinking about it, and that I thought you had pics of that area, in another thread. . .
    Its missing !
    Pics from this post:
    No power feed or gear changes on 1941 Cincinnati no2 horizontal
    Jan 2016
    Indiana
    213
    118
    57
    Quote Originally Posted by texasgunsmith View Post
    From this brochure:
    the pdf:
    LOL I was confused at why the thread title changed, no problem though
    And yes, you are right, apparently it's just plain missing:
    It looks like there's a shaft in there, it's not broken or cut off - I can faintly see some turning marks on the end of it so I'm thinking maybe the shaft is pushed inside? That collar around the outside doesn't appear to have any way to come off either, so I'm guessing it has to be pushed out from the other side (probably necessitating the disassembly of the saddle, ouch). I looked at another newer manual that has exploded parts diagrams and it looks like there's a lever that's just pinned to the shaft, but I'm guessing it's supposed to protrude in order to do so. Guess I don't have a saddle lock LOL. I'm tempted to drill and tap the end of the shaft and see if I can pull it out at least. Weird though, it kinda looks like it's supposed to be that way.
    Feb 2016
    2,266
    1593
    984
    It may or may not be broken, I can't tell. But if not broken, I think it may be possible for it to have gone inside.
    Good news. I think a relatively easy job even if you have to make the parts. It is hard to tell from original late 30's parts pic, because the diagram kind of sucks, though parts are there listed as "eccentric".
    The 1953 manual is more clear, probably the one you mentioned. Parts 506 to 510:
    The end of the shaft, part #506, is eccentric. Or not round, its shaped like a cam lobe. Just turning it will lock it to knee. Maybe why it can be push in ? Its not locking by going in, It locks by cam spinning and pinching knee way.
    Anyway, not sure if handle fell off, or broke off. But Im thinking it won't pull out all the way. If you can get it removed far enough, maybe it just needs the handle. If so just watch how handle is clocked, so you can lock and release.
    Page 96 of pdf, though manual page is 86:
    http://vintagemachinery.org/pubs/2097/22565.pdf
    Maybe a magnet or super glue the end of a bolt to it, then pull out ?
  7. Likes Dope liked this post
  8. #6
    Jan 2016
    Indiana
    213
    118
    57
    I'll play around with it tomorrow night, you've got some good ideas. Drilling and tapping it should work but sounds like a PITA. Hell, if it's stuck in there I might just tack weld a piece of scrap onto it to pull it out. Depends on how lazy I'm feeling.
  9. Likes texasgunsmith liked this post
  10. #7
    Jan 2016
    Indiana
    213
    118
    57
    Okay, not a great update unfortunately. I was not able to get the shaft out, it would just get stuck no matter what. So I actually managed to push it through the interior side and remove it from the saddle.
    I don't think I'm gonna be able to fix that one LOL. Not only was the shaft sheared off at the other end, but it's also bent which is why I couldn't remove it. The rest of the mechanism is gone (long gone by the looks of it). I'll have to see if I can find someone with a junk mill that could remove this unit for me because I don't even know what the remainder of the parts even look like to recreate them. I guess I'll have no saddle lock for a while
  11. #8
    Feb 2016
    2,266
    1593
    984
    I'm not looking at it first hand like you are. But I was thinking of two repairs.
    First one, build it something like was intended. Its basically just a straight shaft with a sort of cam lobe on the end. For the cam lobe to actually lock, I think it would need to begin to lock damn near the peak height of the cam lobe, so that the peak of lobe would be touching ways while pushing straight down vertically on shaft, like a straight 180 degrees straight down, or close to it.
    Might make the cam lobe from a 2nd larger stock than shaft, and either bolt, pin , or weld it onto main shaft. I think very doable, but might need to slide saddle forward enough to install, and some trial and error. Remove cross feed screw maybe, while sorting it out.
    Second potential option. The hole in saddle where we originally saw the end of shaft pushed in. . . Is it possible to tap the end of that hole with some threads, maybe a .5 to .75" deep ? If so, tap the hole and make a bolt/shaft with a brass or bronze insert on interior end.
    You wont be locking saddle from same direction as original eccentric shaft. You're going to lock by basically running a bolt straight in. Brass/bronze tip keeps from scarring anything. Shaft and hole are only threaded toward the outside edge of the hole.
    Just possibilities anyway.
  12. Likes Dope liked this post
  13. #9
    Jan 2016
    Indiana
    213
    118
    57
    Those are some really good ideas. I think tapping it and using a soft-tipped bolt that presses up against the casting just above the cross-feed screw is probably the easiest. Making a cam is a good idea but it seems like it'd be tricky to figure out exactly the right size and shape that works and locks at just the right point. I'd have to take apart that "box" that's just under the shaft, where the splined power feed shaft comes in from the right and take a look from the bottom-up and see what I see in there. In the meantime I've got some feelers out to see if I can source the original parts (or at least see what they looked like/measurements/etc).
    Not a huge deal at the moment, the machine seems to cut great without a saddle clamp for the time being. On my BP, if the saddle isn't locked it likes to walk a little on heavy cuts, doesn't seem like it's happening with this machine (or maybe I'm not taking heavy enough cuts, I've tried 2.5" WOC .300" DOC with a facemill and 1"x1" with a HSS rougher, both in mild steel).
  14. Likes texasgunsmith liked this post
  15. #10
    Nov 2016
    Georgia
    53
    23
    23
    Try Cincinnati Mill Parts l Kearney & Trecker Parts l Machine Replacement Parts
    They sell parts for Cincinnatti mills, they were able to provide me with a new feed dial for my #2ML...
    They seem to be good folks to work with... they sell used parts and also make many new parts.
    -Bear
  16. Likes Dope liked this post
  17. #11
    Jan 2016
    Indiana
    213
    118
    57
    Quote Originally Posted by 682bear View Post
    -Bear
    I agree! They're actually the ones that got me the broken saddle feed screw coupler and saved me a ton of work.
  18. #12
    Jan 2016
    Indiana
    213
    118
    57
    Ended up getting an original shaft + cam from Partsnparts (great place). Now I've got to make a handle for it and figure out how to install it. So many things to do!
