How to remove tool stuck in Hendey 10x30 tailstock quill
Results 1 to 6 of 6
    Jan 2020
    Oregon
    16
    26
    Default How to remove tool stuck in Hendey 10x30 tailstock quill
    Hi -
    I'm not very experienced with metal lathes, and looking at a Hendey 12x30 that's for sale. A drill chuck is stuck in the tailstock quill and I don't see a way to remove it. Sadly the seller has dementia and keeps going at it with levers and drifts and a hammer...
    Is there a trick I need to know, or it it time for to try a tie rod end fork or some other plan-B solution?
    Thanks in advance!
    Sep 2009
    Phoenix,AZ
    1,830
    2775
    467
    Pull the quill out of the TS and use a long drift .
  3. Likes lapoole liked this post
    Feb 2010
    Illinois, USA
    668
    29
    197
    Have you tried turning the handle at the rear of the tailstock to bring the quill all the way in? My Hendey would eject everything fitted in the taper.
  5. Likes lapoole liked this post
  6. #4
    Jan 2020
    Oregon
    16
    26
    Yes, thanks... tried that first. Will try to remove with a drift at next opportunity. Perhaps an ejector pin that should live in the quill has been lost.
  7. #5
    Apr 2013
    Damascus, MD
    1,478
    4242
    846
    If you have enough room, you can put a large enough open wrench between the drill chuck and the body of the tailstock and retract the quill till the back of the wrench is squeezed between the tailstock and the back of the chuck. Back the handwheel a little more and the chuck should pop right out (at least is what has always happened to me, never got any drill chuck popping off the Jacob taper before the Morse taper would release).
    Paolo
  8. Likes lapoole liked this post
  9. #6
    Jul 2004
    Houston, TX USA
    30,294
    Pieces compliments of Pat Black. You can see the smaller front end (of screw) that does the pushing out
    ph
  10. Likes Cal Haines liked this post
