Increasing speed by 50% on mid 50's lathe.
Likes Likes:  0
Results 1 to 6 of 6
    Jan 2005
    Duluth, MN
    490
    10
    44
    Default Increasing speed by 50% on mid 50's lathe.
    I have a P&W Model C lathe with a top speed of 1000 RPM. Sales literature shows 1500 RPM as a factory "ONLY" installed option.
    Do you think I will cause problems by switching out the pulleys on the motor and headstock to get 1500 RPM?
    Larry
    Jun 2012
    Michigan
    9,303
    3164
    3345
    I'm not the lathe guy but here find the manual
    http://vintagemachinery.org/pubs/1412/7012.pdf
    Jul 2014
    Ontario, Canada
    969
    700
    637
    Quick cursory scan of the manual linked above yields on p.28 under Spindle Speeds: "Driving pulley supplied with correct diameter to produce on range or the other as desired."
    Ergo, you can change the pulley only w/no ill effects.
    Jul 2004
    Houston, TX USA
    28,868
    I'll ask something obvious. Model C head stock has pump LOW in back. Do you know for a fact that it is working to get oil way up to the top where its distributed?
    Jan 2005
    Duluth, MN
    490
    10
    44
    RC Mech your cursory scan is far superior to mine as I missed this completely when I checked out the manual on the OWWM site. OWWM also has the Model C brochure where the 1500 RPM is ONLY a factory installed option.
    Thanks for the heads up.
    Larry
    Aug 2006
    Kitchener, on canada
    853
    15
    192
    I would speed it up to make the machine more useful, I imagine it will only run 10 hours a year as a hobby machine
