Brandenberger
Hot Rolled
- Sep 19, 2017
Just starting to cleanup a 1965 K&T 205 SA horizontal.
So far I've drained the knee and column and refilled with kerosene.
A few questions:
- machine's sight glasses on column and knee are very dark/dirty on the inside faces. It isn't obvious how to non-destructively clean them. At least the knee I may be able to reach from the oil fill hole. I suppose I could remove the speed gearbox from the column to get at the two sight glasses there... but hopefully there's an easier way.
- saddle lubrication. It's unclear whether the saddle has been lubricated properly lately, the machine has 50 years of dried on cutting oil. What I can't tell without disassembly is whether there are bijur lubrication meters in the saddle? Or was the oil fed straight from the knee pump through the lubrication line without any meter units? If there are meter units they will certainly be clogged. I do see some copper lines running to the leadscrew nut, so I assume there are bijur meters somewhere.
I ordered a 1/8" NPT hydraulic hose to replace the existing connection from knee to saddle, that looks like the right thread size.
I have all the manuals, but unfortunately the lubrication system for the saddle isn't well described.
A few questions:
