Don Kinzer
Cast Iron
- Mar 18, 2002
- Portland, OR USA
I finally got around to using the K&T 2CHL (that I bought about a year ago) to make some chips. Before starting, I wanted to check the alignment of the universal table with respect to the knee ways. The scale read 0 but I wanted to check anyway. I did this by putting 1-2-3 blocks between the table and the knee way on either side (supported by some scrap wood) and then carefully moving the table toward the column. When slight resistance was detected, I checked the ability to move the blocks and one was somewhat difficult to move and the other one was just a bit easier to move. From the feel, I'd guess that the difference might be a thousandth or two at the most.
I looked through the Operator's Manual that I have for it (which covers the 2CHL Universal) but there was no mention of how to swivel the table. Looking under the table, I found four hex head bolts (two on either side of the knee) that appear to be in a position that might serve as a clamp on the swivel. They were very tight - one moved slightly with significant torque and the others not at all. I didn't want to force them due to not knowing what they are actually for. I've attached a photo of the left side of the knee with two hex heads circled in yellow.
So, the question is ... how does one go about loosening the table to swivel it to a new position and then re-clamping it?
Also, is there a better way to assess perpendicularity of the table with respect to the column? My first thought was to mount a dial indicator on the column with the plunger riding on the back of the table but I concluded that it wouldn't show any difference as the table moved. My next thought was to measure the spacing between the knee way and the table on either side but chose, instead, to use the 1-2-3 blocks and check the "feel".
Edit: I should have mentioned that this is a horizontal mill.
