K&T 2H Vertical dimension question
Likes Likes:  0
Results 1 to 4 of 4
    Jul 2006
    beloit, wi
    89
    Default K&T 2H Vertical dimension question
    Hi All,
    I'm wondering if anyone knows the distance from the center of the spindle to the frame of the machine? How about the distance from the back of the table to the center of the spindle with table as close to the front of the machine as possible? I'm trying to figure out how wide a piece can be milled on edge without changing the set up. Thanks.
    Patrick
    Jul 2004
    Houston, TX USA
    31,969
    E dim for C/L spindle back to "frame" ( a horizontal dim) is 14". This is where the "frame" is "scooped out" above the column ways on a 2H vertical
    Feb 2016
    1,773
    1203
    646
    Jul 2006
    beloit, wi
    89
    Thank you both for that information.
