Andy FitzGibbon
- Sep 5, 2005
- Elkins WV
Anyone removed a gearbox from a 2H vertical? The starting lever (clutch lever) shaft is disengaged from the gearbox, and the retaining nut is removed from the clutch shifter rod. As far as I know, the box should slide out once those are disconnected. It slides freely for the first half inch, but beyond that I encounter resistance.
The punch-mark goonery on the pulley hub nut was not my doing, by the way.
Thanks for any help,
Andy
Sent from my SM-G950U using Tapatalk
Andy
