Will McRay
- Dec 31, 2017
Been working on this mill off and on due to life and work. Had to fix some broken bolt issues behind the clutch pulley, oil leak at the vertical rapid and coolant pump shafts and fix one telescoping joint on the forward Y axis. Motor was not securely mounted when I got it so I addressed that and new belts. Flushed oil system and she runs good. Took this week off work to re-engage the project and finally got it stripped, primed and painted. Rust oleum charcoal grey oil based. Thinned, mixed and sprayed. Close to the original color I believe. Few more things to do and she will be back in service.
