K&T milwaukeematic IIIb - Page 3
Likes Likes:  0
Page 3 of 3 FirstFirst 123
Results 41 to 53 of 53
  1. #41
    Aug 2007
    Holmen, Wi
    199
    15
    Here is the 3rd and 4th rigid tapping attempt. (all successful)
    we have to play with the vfd for braking and acceleration. it was setup quite a long time ago and I don't remember how it was setup. it has braking resistors but the transmission has quite a bit of rotational mass..
    1" 16 tap
    60rpm
    YouTube - kearney and trecker rigid tapping 1 inch hole.
    400rpm
    YouTube - kearney and trecker rigid tapping at 400rpm
    shot of the tool changer swapping out the 7/8" drill with the tap drill.
    YouTube - another tool change with a 1 inch tap and 7/8 inch drill
    sam
  2. #42
    Aug 2007
    Holmen, Wi
    199
    15
    Oh - this is the spindle encoder mount - showing the collet unclamping also.
    YouTube - K&T spindle encoder with collet unclamp/clamp
    sam
  3. #43
    Aug 2007
    Holmen, Wi
    199
    15
    so - here is a video with it all coming together. This is a short gcode
    program that spots, drills, taps a hole. At this time emc pauses motion
    when the tool prep is happening - so I modified my ladder so it sends
    the tool prepared bit instantly but the actual tool change is inhibited
    until the ladder is done with the tool prep. (if that made sense.) The
    program is short enough that for a few of the tools the tool change
    sequence has to wait for the prep.
    YouTube - Kearney and Trecker CNC running simple program. (tool changing and everything)
    After this video was done we played with the spindle vfd and got the
    acc/dec twice as fast.
    sam
    ps - yes the 7/8" drill is bent. (best enco had 15 years ago )
  4. #44
    Aug 2007
    Holmen, Wi
    199
    15
    finally hooked up a probe. will make things a bit easier
    YouTube - ‪Kearney and Trecker probing with emc2‬‏
    sam
  5. #45
    Aug 2007
    Holmen, Wi
    199
    15
    The old control used the spindle temp to offset the z axis. The spindle extends past the ways around 11 inches so from cold to hot is can 'grow' around .003". I had found myself 'tweeking' programs when running from cold to hot to compensate. Well I got sick of that pretty quick and the temp sensor was still in the spindle (thermistor) so I hooked that into an arduino and am using that to offset Z autmatically. So far so good - no more thinking I tracked the voltage vs temp vs growth and it turned out to be linear. Yay.
    So I just scaled and offset the voltage signal from the arduino and sent that through a few components - It goes in to a mux2 so that I don't apply the offset while the machine is homing.. Then through a limit3 component that limits its velocity, acceleration, min and max so if something goes wonky it doesn't send the axis into the limits. From there it goes through the offset component. This offsets the output and feedback from emc so that in effect - motion doesn't know that the Z axis is being adjusted. It sort of happens between emc motion control and the hardware. (In emc's the hardware abstraction layer (hal))
    Emc2 - Using temperature to compensate Z axis for spindle growth. - YouTube
    Crappy loud video...
    sam
  6. #46
    Sep 2002
    Lawrenceville GA USA
    6,175
    697
    1315
    Cool....
    Charles
  7. #47
    Nov 2012
    Sask, Canada
    11
    This was (and still is) a really cool thread! Any news on this machine? Did it live happily ever after?
    Grant
  8. #48
    Oct 2011
    Sweden
    56
    444
    24
    Quote Originally Posted by Twistdrill View Post
    Grant
    I couldnt agree more!
    Very impressive work, i have been following this tread for a long time, and i keep looking every now and then for updates.
    And horizontals are very nice machines if you ask me, i like them alot.
  9. #49
    Aug 2007
    Holmen, Wi
    199
    15
    no new updates. This is in my dad shop - he is retired and working on his own projects. (he is always doing something) So it mainly gets used for his own projects - mostly. He takes on jobs if they are not too stressfull
    Still going strong though - and it is nice having access to such a nice stout machine.
    He has a acroloc now that he is going to convert to linuxcnc. (got it exceptionally cheap - dead control)
    sam
  10. #50
    Oct 2011
    Sweden
    56
    444
    24
    Any chance of a new video of one of these jobs running on the machine?
    I am pretty sure i am not the only one who would like to see it making some more chips and a few toolchanges.
    I think the audience will be happy just to see it move.
    I know i will!
  11. #51
    Aug 2007
    Holmen, Wi
    199
    15
    Sure - when we run something of any quantity - I will make a better video
    Don't know if this was posted or looked at - simple hand changing of tools (our probe need to be plugged in so doesn't make for automatic tool changing.)
    Probe and mill - YouTube
    some cylinders we bored/honed then this proccess was putting an o-ring notch in each end. Slap it in the chuck - probe for center and surface - mill grove. (not high production < 20 parts.)
    sam
  12. #52
    Oct 2011
    Sweden
    56
    444
    24
    Great!!
    Looking forward to see more of this old hot rodded hmc in action.
  13. #53
    Aug 2007
    Holmen, Wi
    199
    15
    Still kicking!
