danil
Cast Iron
- Feb 8, 2008
- Mishawaka, IN
A coworker broke the handle off my 205 Kearney.... I use this mill daily.
Wanted to see if there were replacements out there. The handle had a pin that that pressed into the crank handle(on the x axis). I temporarily have a .312 dowel with a piece of delrin for a handle; the .312 dowel is slip fit into the crank.
Originally, they must have cast in place or pressed the shaft into that handle as it is free to revolve around the pin. It had to be a .313 press fit-- you can see the cast bushing in handle piece. I can something work, but prefer to keep as close to original.
Suggestions?
Suggestions?
