adammil1
Titanium
- Mar 12, 2001
- New Haven, CT
It has been discussed here before but now the thread seems to have disappeared, so I am posting it again. Not long ago our railroad musuem purchased the following mill with the intent of scrapping a trashed Bridgeport base and modifying the ram to fit.
As of Saturday we milled out one side, but it will still need 1more day till the conversion is complete;
Here's some photos of the job so far. First operation was to mill a strip on the side of the machine so that we could get a good reference surface to locate the ram on a side. Then we milled the dovetail. Since my cutter wasn't wide enough to hit it in one pass, I used a red marker to show contact. If you look at the 3rd photo below based on the pattern where the cutter has just barely taken off the ink on one side, but left it on the other I am pretty confident that we are good here. You can't feel much of a ridge at all. Next we cut the strip on the other side.
Only one thing that still has me scratching my head and thinking is how best to put a slight radius on the bottom of the dovetail. I am a bit concerned that I have created a massive stress riser there, and that we really need to blunt the angle. I am thinking I may try to delicately use a die grinder, or maybe even grind the end of a file to be a scraper and get a radius down there. Does anyone have a better idea?
Anyhow now it is time to figure out what oil I need to buy and how much do you think I need?
For all I know last time the oil was changed on this girl was WWII so I want to drain it all and start fresh with quality oil. Anyone care to guess on quantity and type of oil? DTE Heavy Medium (? Gallons), 1 gallon Vactra 2 I have on the list. Would DTE Heavy medium be the good one to choose and how much do you think she will take? Anyone ever done an oil change on an old girl like this?
I will keep you all posted on the rest of the conversion, but it probably won't happen till the week after next.
Adam
Adam
